Recent news
  • The developing version can be obtained via svn
    All release versions can be obtained from the download section
Execution architecture
A C++ white-box object-oriented framework dedicated to the reusable design of metaheuristics
  • Portable on: Windows, Unix and MacOS
  • Parallel and distributed architectures (MPI)
  • Grids (Globus, Condor-G/MW)
Support
Tutorials
  • More than 20 lessons to dive easily into ParadisEO
API doc
  • Template tools, classes and functions are fully described
ParadisEO is based on EO (Evolving Objects), a template-based ANSI-C++ compliant evolutionary computation library. ParadisEO is distributed under the CeCill license and can be used under several environments thanks to the CMake build process.
